Pump was running fine yesterday and last night. This morning I cut the switch off at the pole like I always do and turned the handle to backwash. When I went to cut it back on it would not come on. Checked the breaker and it had tripped. Went to flip the breaker back on and it immediately tripped again. Unplugged the pump "twist lock" and flipped the breaker back on and it didn't trip. The electric pole by the pool also has a normal receptacle on it so I plugged the pump in to the adapter and plugged the pump in to the regular receptacle and it tripped that breaker also. Both GFCI breakers are tripping when you connect the pump to it. If I plug anything else up to the pole the breaker does not trip. Is this a bad pump or what? Thanks in advance.
