Bad Filter Seal/Oring = cloudy water?
Par4monkey
Active member
Jul 11, 2020
37
Pittsburgh, PA
Hello. I have a Hayward SwimClear Cartridge Filter for my 16x32 inground pool. I use the BBB + M method to maintain my pool with the Taylor 2006-k test kit. The rubber o ring (metal inside) that divides the lid of the filter from the base needs to be replaced. Very minuscule leak right now due to the metal coming through the rubber portion. New seal arrived this evening. My question…could the faulty seal/o ring cause cloudy water? I religiously test my water with my kit and rotate through (3) sets of cartridges. I will be cleaning the cartridges again tomorrow when I replace the seal/o ring tomorrow but wanted to see if the cloudy water could be linked to the faulty seal/o-ring. Any feedback is appreciated! Thank you!
Par4monkey
Active member
Jul 11, 2020
37
Pittsburgh, PA
I should also add that I need a new pressure gauge since mine is broken
an1vrsy
394
Las Vegas, NV
Pentair Intellichlor IC-60
Could post up a full set of your test kit results and photo of the cloudy water?
Jimrahbe
22,829
Bedford, TX
Par,
Absolutely not.. Your leak has nothing to do with your cloudy water.
Your cloudy water is a chemical issue.. Either you have algae or you added something we do not recommend..
My "guess" is that you have algae because you are trying to keep your FC too low..
We need a set of test results.
I suggest that as soon as you get your leak fixed that you run an Overnight Chlorine Loss Test.. OCLT... Overnight Chlorine Loss Test
Par4monkey
Active member
Jul 11, 2020
37
Pittsburgh, PA
Par,
Ok, thank you. I didn’t think so but since I keep reading 90% of cloudy water can be traced back to filtration issues… it made me wonder.
If my FC needs to be at least a 3 prior to running the over night chlorine test…..how much time needs to pass between me adding liquid chlorine (after sundown) and getting that initial chlorine reading prior to going to bed?
Thank you for your response!
cowboycasey
8,648
Southern OK
CircuPool SJ-40
at least 30 minutes...
cowboycasey
8,648
Southern OK
CircuPool SJ-40
you have to start after the sun goes down tonight, so 9 pm or so.. measure FC then measure it again this time tomorrow morning.. you want 6 hours between the FC test overnight..
Par4monkey
Active member
Jul 11, 2020
37
Pittsburgh, PA
My test results and picture from 7am (east coast) *no visible signs of algae growth
PH 7.5
TA 100
CH 110
CYA 50
FC 3
CC .2
TC 3.2
Par4monkey
Active member
Jul 11, 2020
37
Pittsburgh, PA
Par,
cowboycasey
8,648
Southern OK
CircuPool SJ-40
with a CYA of 50 and FC of 3 you are below the minimum, you fell of the cliff and need to do a SLAM.. You never want to fall of the cliff.. stay away from the minimum...
Stay at or above the target, for 50 CYA is 6 to 8 FC Chlorine / CYA Chart - Trouble Free Pool
