Yesterday I was able to get everything hooked up with the pool. Sand filter was completely removed by the last homeowners. So the sand filter has brand new sand. My question is the pressure out of no where jumps 5-10 psi after 30-60 mins of the pump running. My water is blue, but pretty cloudy. The return jet will have decent flow and slow bleed off till you can’t see the water ripple. Is this normal since I just opened or is there something going on?
