timerguy
I've gone back and forth w number of times line you said, there's only one line from the pump and that's the one to the bottom of the filter there is NO waste(bypass) capability. There is no line from the pump to the multiport. I thought the hose coming out of the pool side was a return(I see now it is). I have no idea what the line towards the top of the pool is (I can see now that's probably the only drain line coming from the skimmer) I cant tell what the lower or the two lines coming out of the multiport goes to (that IS a return. Ok, I can see it more clearly now, the line DOES go from the pump to the multiport so there IS waste.If you go back and forth between the two pictures you can see the intake hose from the skimmer going to the pump and the hose from the pump going to the multiport valve and the return hose leading from the multiport valve back to the pool. What you don't see is a "waste" or "discharge" hose, just that white valve stuck in the outlet.
No clue what you are referring to as a second separate line from the pump to the multiport for wasteThere is only one line from the pump to the multiport valve. Pump supplies water under pressure to the valve and the valve determines what it's going to be used for/where it goes.
Now my only question is is there a bottom drain?
