Bsaed on all the feedback here, problems with the pump are my primary focus and the first thing that I will have them check. With respect to the plumbing, here is the full description of what the PC said about the "hydraulically inefficient" plumbing... "The plumbing configuration is not hydraulicly efficient as the system is bushed down from 3” to 2” pipe before the system splits off the two filters."The concern I have is what does that actually mean? Is it hydraulically inefficient because it should be 4”, 6”, 8” in diameter?….. or because it has too many restrictive fittings….or because anything? They have not defined the actual root cause, which leaves you with a potential fix that could mean re-plumbing everything depending on the knowledge/expertise of the diagnostician
I think this is the section of the plumbing they are referring to. Does that make sense.... or is this not likely to be a source of the problem that needs to be ruled out?
