Autopilot warning check clean cell problem
DLSDO
0
330
Midwest
I have a Dig 220, Autopilot rc 42 and am seeing the "check clean cell" message. I live in the Midwest and only use the pool 4 months a year. The generator is 5 years old. Salt level is 3200 ppm, 2.8v, 3.6 amp after boost test. Is it likely a bad cell? What should I do next? My chlorine levels so far are still good. Do you think it will last at least until I close the pool in a month? I appreciate the input and suggestions.
Did you check to see if you need to clean the cell? Are you managing your CSI?
I think some of the SWCG's you have to reset a timer for the check cell light. It is kind of a reminder.
