Automation with SWG?
xyz
641
Escondido/CA
Well, I took a look but could not find it. I'm going to guess that *maybe* Brian was the one that suggested you could bend the tab to make the flow sensor more sensitive?
Anyway, the idea is there.
I also had a thought. Do you have a straight section of pipe going to your cell? I noticed one guy had trouble with the flow switch after 10-40 min; had his PB add 18" of straight pipe, and all was well after that. Also, there I would think you could do the same thing with a cross baffle of stainless sheet metal in the input pipe. What I'm guessing at is that there may be enough turblance at the inlet to, every once in a while cause the flow switch to bounce, and that could be the issue.
Also, adding a little drag to the flow switch could also reduce the need for as much flow.
By the way, I can run my system at 750 without losing the flow light, but I've made my system to be very free flowing. What is your gauge pressure?
J
peterl1365
257
Murrieta, CA
Just to add my two cents, the Pentair VS+ET4+IC40 automation system I specified in my pool 10 years ago was the best investment I've ever made.
The VS has made electrical costs practically a non-factor, and the ET4+IC40 reduces maintenance to a once-per-week tweaking. Like others have said, the Pentair cells are expensive, but the convenience is worth it. I had switched to tablets for about two years when a cell failed prematurely, and it was a much harder job to maintain proper chlorine levels.
xyz
641
Escondido/CA
Up front cost is more expensive, however, the IC60 is the most (well on part with the most) inexpensive solution if you measure cost per Lb of chlorine.
