Automation - Where to Start?
Geebot
Aug 19, 2013
952
Having replaced my antique heater and pump in the last 12 months with a new Raypak and an Intelliflo I am now in a position to enjoy late 20th/early 21st Century conveniences. Thinking about dipping my toes into automation but have no idea where to start. Can anyone point me in the right direction?
Are you interested in using commercial controller(s), or in designing and building your own?
If the latter, start of by buying a USB to RS-485 interface for your laptop, and determine if you can control the pump speed using the reverse-engineered protocol available on-line.
G,
If you enjoy the type of thing that Phil brings up than it makes sense to get knee deep in it.. If you just want to enjoy your pool, you have little choice in equipment.
Since you have an IntelliFlo pump, the only common sense Automation system for you is the EasyTouch...
Below is something that I have posted before, but it gives a basic idea of what the ET can do...
1. Automation will help you with pool maintenance, but it will not replace the need for you to test your water, understand what you are looking at, and then making sure your water is balanced. (Another reason you need the accuracy of the TF100 test kit.)
2. The main downside to automation is cost. So before going too far down this path, you might ask your PB what it's going to cost. That said, the best time to install automation is when the pool is being built, because all the connections to the system can be made without having to figure out how you are to get power across 50' of new deck. Also, the additional cost, when compared to the cost of the pool, will be miniscule.
3. Automation systems work best when the same brand is used because then the pieces can "talk" to together. So, in your case I would recommend the EasyTouch 4 (or 8) that has a built in power supply for the SWG and generally comes with the SWG and two valves. ScreenLogic2 is an absolute requirement if you want to be able to control things from your PC or Phone.
Here is a list of what I think the advantages are:
1. Appearance. Instead of having a bunch of different boxes hanging on your wall you have one, professional looking enclosure.
2. Circuit Breaker Panel. The bottom half of the enclosure is a circuit-breaker panel where the breakers for your pool equipment (Pumps, Heater, etc.) are located. This panel is also an excellent place to add surge protector, which is an absolute must if you have the Intelliflo pump. Even if you do not get the automation, make sure your PB includes a surge protector for the pump.
3. SWG Control. Without automation, your SWG will have to have a timer, synced to the pump timer so that it does not run when the pump is off. This function is built into the EasyTouch.
4. Spa mode and SWG output. Normally all the water flows through the SWG, so when in the Spa mode, the EasyTouch reduces the amount of chlorine the SWG produces, so that the Spa users are not subjected to high levels of chlorine.
5. Pool Lighting. The EasyTouch allows you to control your pool lighting from your PC and/or from a schedule. This is another reason to add the EasyTouch now. Once your pool light is wired to switches inside your house, it might be very difficult to get the wiring to any automation system.
6. Control of Spill-over and bubblers. Right now I'm sure you are thinking I want that spillover running 24-hours a day because it is so beautiful.. Well, after a few weeks of having your pH go through the roof, you'll appreciate the ability to only turn it on, when you want it on. The same with the bubblers. With the Easytouch, you can program them to run on a schedule for a few minutes a day to keep the everything properly chlorinated or when you want to "show off" to your guests..
7. Relay Control. The EasyTouch 4 has four (really three) relays that can be used to control other things, such as, Booster pumps, Spa blowers, landscape lights, etc…. The EasyTouch 8 has eight (really 7) relays.
8. Built in Valve controls. The EasyTouch has the ability to control 4 valves. Two work for switching between the Pool and Spa modes, while two others can be programmed to do whatever you might want, like bubbler control. I would note that a lot of bubblers are controlled by manual valves that cannot be automated. You need to be sure to tell your PB that you want Jandy style valves for your bubbler control.
9. Heater Control. The EasyTouch can control your heater.. So, you can be inside and tell your PC what temperature you want the Spa to be and it will tell you when it is ready.
10. Solar System. The EasyTouch has a built-in solar controller.. It does however use one of the valve outputs to run…
11. ScreenLogic. ScreenLogic allows you to program the EasyTouch with various schedules. It lets you see most all of the inputs and output to the EasyTouch and lets you decide what you want on/off and in the case of your SWG, lets you adjust the % of output on the fly.
12. Variable Speed pumps... The EasyTouch can be programmed to adjust your pump’s speed. So when running just the pool, it can run slow, but when running your waterfall, it will automatically increase the speed to make your waterfall or other water features look exactly how you want them to look.
The more things you want to control the more automation makes sense.. If you just want to control pump speed and nothing else, there are better options..
Thanks for posting,
Jim R.
