- Mar 6, 2022
- 9
- Plaster
- Pentair Intellichlor IC-40
Looking for some advice.
I have solar heating. It is controlled by a simple Hayward Aqua Solar Control Panel.
I just upgraded to a Jandy 2.7 VSP.
I would like to set my pump to run at a low speed most of the day but when my solar controller calls for heat, I would like it to trigger the VSP to increase the pump speed to accommodate the additional flow needed.
My PB initially installed an IQPump controller. The thought was just to guess the hours of the day the solar will run and schedule the pump accordingly. However there are days when the heat will not be called for so o don’t see a need to run the pump faster for the entire day.
I see this as a simple trigger relay. Just want the pump speed ramped up of solar heat on. If it is running on low, then it increases. If it is already on high speed, than it stays there. Once the solar shuts off, I want the pump to run on low again.
I am trying to upgrade to the new Jandy TCX controller as I believe it will accomplish what I want to do but not sure exactly how to wire it all.
I have skimmed the instructions but they are confusing. Anyone have some advice on exactly how to wire it? I was told the Aqua Solar controller has a relay out. If it does, how do I wire it to the TCX and how do I program it to do what I want?
I also have a SWG
TIA for any advice.
I should note, at this time, I am not interested in Full Jandy system. Although I know it will do what I want, it is simply overkill for my pool set-up.
I also have a SWG
TIA for any advice.
