- Jun 7, 2017
- 46
- Plaster
- Pentair Intellichlor IC-60
Moved from here.
While I agree that drop based testing is the gold standard - we also should consider the fact that “smart pools” are here and automated testing is the next logical step. I have not had a chance to test this yet but likely going to try. Since I pay next to nothing for pool chems [ie SWG (water softener salt), borax, calcium chloride, etc] - I don’t mind investing in some innovative tech which may be of value.
Granted testing only takes a few minutes - but if Sutro can provide accurate results then that is less time I need to spend testing my water. Whether it’s Sutro or someone else - we will see offerings which use machine learning, analytics, etc - to prescribe what to do for the user as opposed to the user reading a test result and tell them to add this or add that. Being able to predict a water balance issue would also be valuable - the more users, the more data and the smarter the offering becomes.
I do water testing because I need to - but there are many others things I would rather do. Manual water testing will go by the way of the slide rule at some point - the internet of things is now touching pool chemistry and there are some pretty great benefits as it gains adoption and maturity.
Just my 2 cents.
Just my 2 cents.
