So thinking about converting to salt... General consensus is to oversize the generator. Pool is 13k gallons. I want to get a Chlorsync generator to interface with my existing Poolsync WiFi heat pump controller. Chlorsync comes in three capacities: 30k, 40k, and 50k.
My goal is convenience over cost. In practice, could I get a generator large enough so that I could rely on it to produce enough chlorine to avoid manually adding (liquid) chlorine during routine use? I consider routine to account for occasional higher chlorine needs such as for heavy use. I expect to manually add chlorine at pool opening or unforeseen circumstances. My goal would be to go an entire season using only the SWG for chlorine needs except for the rare one-off situations.
I estimate my pump should run 6-8 hours a day for filtration. I run the pump during the hours of 10am-6pm. This allows my heat pump to run when it's most efficient (higher air temps vs. at night). If I get the 50k SWG, would I have an issue with precise control if I have to turn the % setting down very low? For example, if running it at 5% is about right, I don't have much adjustment between too little and too much (in 1% increments) assuming the SWG runs with the pump.
My main question is whether I should automate the SWG so that I can control the "on" time shorter than the pump's "on" time? I don't think I can schedule the SWG with the Poolsync app, so I would add a separate controller. My thought is that I can run the SWG at a higher % for less time for more precise control, and I can run it for longer and/or at a higher % when I need a boost. Would there be an issue with chlorine concentration swings if the SWG is only operated for a short amount of time each day (e.g. 50% for one hour vs. 10% for five hours)? Would I lose too much chlorine before the next day's run time (such that it drops too low during off periods), or have way too much during/after an on period, if it's not run for very long?
I'm trying to decide which generator to buy and if I need to add a controller for it. It really wouldn't hurt if I go ahead and add the controller since I don't have to use it to reduce the "on" time. I just don't want to end up buying a generator too large and have a hard time controlling it for consistent and proper chlorine levels, but I would like to get one large enough to give a boost without having to manually add chlorine.
