Hello Dirk, Brian, Jim,
My IPH controller crapped out a while ago so I decided to wire up a 24-volt power supply into the AUX 3 relay on my easy touch powered by an AFCI breaker I added to my panel. I named the relay "ACID PUMP" and set the function to Generic. I can manually press the AUX 3 button to switch the IPH pump on and off no problem. I also have an IC60 chlorinator that is plugged into the easy touch and I am happy how this is controlled. When the IPH controller was working it ran once per hour set at 100% based on the acid consumption of my newly remodeled pool and on me running my pool pump for 12 hours. My dilution is 2 parts acid to 1 part water. I believe if the IPH controller is set to 100%, it runs for 60 seconds each hour. Is that correct? That equates to about 11 or 12 minutes per day of total IPH run time.
My question to you guys is this:
In an ideal world I want to automatically turn the IPH pump on, a few times per day, to provide the proper acid dose (11 minutes total of IPH run time) for my pool. The IPH pump run time could be adjusted up or down to regulate the amount of acid delivered to the pool.
Ideally this strategy would deliver the acid in smaller doses throughout the day during the pool pump run time. My pool is scheduled to run from 7 AM to 7 PM right now.
Is this multi dose per day scenario possible to accomplish using the easy touch schedules, egg timers, etc?
Is doing this overkill and should I just run the IPH pump once per day for 11 minutes? I'm kind of worried about the pump overheating if it runs for 11 minutes straight, but I'm not sure if this really matters.
Someone also mentioned an egg timer and that it would be a good idea to have this set up properly so if the IPH got switched on by accident it would only run for the length of the egg timer as a safety measure.
Any help and support would be much appreciated.
thanks,
Scott
thanks,
Scott
