Built a PVC tank and stood it on the ground next to the pool. I kept track of the amount of water that was sucked out of the tank each hour. The flow rate dropped each hour as the level dropped lower in the tank. There was not enough suction to drain the tank to the point that it began sucking air.
So..... it appears I can make a tank that could be hung horizontally from the side of the pool and simply raise or lower the tank to adjust the flow rate to deliver the desired amount of chlorine. I have so many things going on at the moment that I have not assembled a tank to test the theory, but I feel confident it will work.
