- Feb 27, 2015
- 1,402
- Plaster
- Jandy Truclear / Ei
Hey guys - I've got a pool with an attached spa. It isn't feasible for me to run the spa completely independent of the pool (except when in spa mode) because I have a huge waterfall that spills over into the spa, then into the pool.
I know it sounds crazy wanting to heat the spa in 100+ degree temperatures, but I hurt my neck and really want the heat & jets. My PB just warned me that heating the spa in this type of heat, will raise my pool temps significantly & I won't be able to cool them down.
Right now my water is about 86 in the AM (after running water features a few hours at night) and about 89 in the afternoon.
Does anyone have a similar setup where after you heat the spa, and are done, the water will mix with the pool? How much does it raise your pool temps? Am I crazy? Should I just leave well enough alone?
