Looking for a survey / thoughts from people on their performance and maintenance experience has been with these "2" cleaners. Given they come by different names, if you have one of these models (not interested in the MX8) what was your parts requirements and frequency. I plan to buy a new one and like the Atlas for wall cleaning capability, but no not want to get into heavy maintenance/parts requirement.
I have owned TPC 4 wheel (old version) for over 10 years and have put several sets of various gears. Into it. 3 Large drive gear, small drive gears. steering assembly 2 or 3 times, turbine hub once, 1 set of reduction gears, wheel assemblies, and tires. I also found that the steering gear shaft to large drive gear gets worn and causes deflection and main drive gear is pitched forward disengaging it from small drive gear. I started adding a .22 caliber cleaning patch in the splines of that steering gear/shaft to large drive gear connection as a packing to take up the slack vs buying more parts (actually works really good to prevent that gear mesh separation).
My cleaner stays in pool year round and it runs daily, so could just be a mileage issue. I remove it for heavy chemical loads, shocking etc.
I know what I have with parts requirements for TPC - just wondering if the Atlas is worse or better.
FWIW: My cost difference is 90.00 with the Atlas being higher.
30,000 gal
8.5' deep end
30,000 gal
8.5' deep end
