Paul E
1
Addie16!
I opened up my pool and the water was crystal clear. Recently the water has turned murky. I put in clarifier and ran the pump for over 48 hours. I used an automatic pool cleaner and was able to get some debris out, but still cloudy. Then I tried Shock and that doesn’t seem to help. I read on another site to use clarifier and don’t run the pool pump for 8 hours and then vacuum. I am
In the process of trying that. I have a salt water pool with a cartridge filter. Salt level is good, PH is good, and filter is clean. What am I missing and what should I try next?
Hey Paul and Welcome. :wave:
Whatever you do, do one method and stick with it. If you mix and match you foul up even the few ways that work. It may even make the ways that don't work worse than simply not working.
You need to
SLAM Process
To do so you need
Test Kits Compared
Then get a grip on the
Pool Care Basics
