- May 13, 2011
- 346
- Plaster
- Liquid Chlorine
- Hayward Aqua Rite (T-15)
Thanks to this forum I discovered the AA treatment years ago and have done so a few times successfully over the years. Latest situation, after the Houston freeze the obvious problem was a cracked and leaking salt cell. That was checked and replaced. I was out of town and returned home and discovered the newish heater had a fault.
My pool equipment company, the owner always comes to my house, is coming today and will make it right, that I am sure of.
I want to do an AA treatment before water and air temperatures heat up. I am usually in the pool the last 2 weeks of March. I want to be able to turn the heater on and make sure it works. I usually have to let the chlorine drift down and lower the PH. Since the chlorine is down can I do AA treatment now. Pool looks good, clear sparkly water, but I know I have to get the chlorine up either today or tomorrow at the very latest.
Plan is to lower the PH, do the AA treatment, add sequestrate, and then boost the chlorine with bleach. I will try to use the smallest amount of AA, and I am home so I can check my chlorine many times to gradually bring it up. Can I proceed or should I wait until the cell has flow and the heater fixed.
Chris
FC 0
Ph 8.2
TA 70
CH 320
CYA 0
Salt 2000
Borate 0
Temp 71
CSI 4.4
Chris
FC 0
Ph 8.2
TA 70
CH 320
CYA 0
Salt 2000
Borate 0
Temp 71
CSI 4.4
