Our pool builder has been an absolute nightmare. Our liner install was a couple weeks ago and in one corner there is air behind the liner where you can push the liner to sit against the corner with your hand, but it's stretched in a way that it does not sit against the pool wall in this corner if you don't push on it. Will the liner stretch in this corner over time, is a small air pocket like this an issue I need to worry about?
On the other side of the pool there is a 5-6 inch wrinkle about 1/2" high. I assume that a single wrinkle like that on the side wall won't be a big issue?
