My readings today are as follows:
TA: Between 80-90ppm
pH: 7.8
CYA: 50
CH: 240
FC: 4.0ppm
Not sure of what the temperature is. I calculate my CSI to be a little around zero. My question is, is the pH okay at this reading of 7.8 or should I bring it down to around 7.6 I which will bring my CSI a little below zero. Isn't pH range between 7.2-7.8? I am on the high end of the scale. My pH changes by 0.2ppm every day and I don't want it to go too high. I entered my signature already but don't know if it is showing up.
pH: 7.8
CYA: 50
CH: 240
FC: 4.0ppm
