Arctic Spa SWG
You need to add the #/day of your swcg yourself.
This may or may not be listed in your manual. It may be listed in grams per hour & need to be converted.
Artic spas has a couple different swcgs.
May need to call them to inquire about this info.
Reactions: Newdude and JoeSelf
Fwiw I didn’t even worry about calculating my swcg production in poolmath for several years and then it was just for curiosity purposes and to help calculate the lifespan of my cells.
I mainly use poolmath to figure manual additions for my spa. I determined my cell run time the old fashioned way- testing then adjusting & testing again.
The article spas spa boy set up has orp if I recall & it’s supposed to adjust itself based on those measurements correct?
