- Jun 24, 2021
- 15,864
- Vinyl
- CircuPool RJ-60 Plus
Yep, if FC is down to 4 tomorrow add enough to get to 6, that will add more cya. Rinse and repeat until your CYA is 30.
After tonight your CYA should be around 20. Until you get to 30, your target is 6.
When you get to 30 CYA, then follow this...Link-->FC/CYA Levels
After you get to 30, dose above range with liquid chlorine so that you are IN RANGE when you test...rather than testing in range, letting it drop, dosing to get back in range. This will avoid algae.
When you get to 30 CYA, you are safe to spa with FC up to 12.
Check your CYA weekly, If you are low, use dichlor until you are back to 30, then continue with LC.
