- Jun 28, 2016
- 199
- Vinyl
- CircuPool Core-15
Background - new liner and water 4/26/24. Followed TFP instructions as suggested. Readings as of yesterday:
FC 2.5 (added more chlorine per pool math)
pH 7.2 (added Borax per pool math - need to raise a little more)
CYA 60 (need to increase to 80 - water temp 62 so taking a few days)
TA 50 (have not adjusted)
Salt: 2800 (per pool math) - tested with new Taylor K-1766
Turned on SWG (replaced with aftermarket T-15 in May 2021. AQL-PLUS shows Check system very low salt Set chlorinator to 10%
Tried all the tricks - cleaned sensor, cell looks fine, turned system off completely and restarted - all to no avail.
Diagnostics:
+29.46V
69 Degrees
+1.87A
500 ppm
-28.19V
69 degrees
-3.51A
1300 ppm
I read to try resetting the system since all the water was replaced. The only info I can find anywhere speaks to turning off the "physical switch" which we do not have. Called Hayward for help to reset (manual does not address this) and then want me to have a dealer diagnose. Told them I don't want to spend $150 for a service call. I called Salt Solutions and guy said based on readings, the cell has gone bad. Said I should have gotten 4 years out of it, but ... proper balancing, etc. There are no error messages at all on the AQL indicating any issues with the cell.
Is there a way to reset or do I just bite the bullet and buy another T-15? Thanks in advance - meanwhile I'll use liquid chlorine and continue to get my CYA and other chemicals balanced.
Many thanks!
Diagnostics:
+29.46V
69 Degrees
+1.87A
500 ppm
-28.19V
69 degrees
-3.51A
1300 ppm
Many thanks!
