Aquarite 900 Hayward
Drewalbiston
4
Got it installed earlier this month.
Put salt in the pool, chemicals are in balance.
Check Salt and Inspect Cell light are on. When I reset the cell, still reads zero salt, zero salinity and zero amps.
I put in the salt yesterday and have been running the pump for almost 24 hours, have turned the salt cell on. Water temp is about 60 degrees. Hayward system registers at the stand 77 Degrees.
Anything I can do or just wait?
-Drew
Welcome to TFP.
This is the basic information we need to know in diagnosing a problem:
  • Report all diagnostic readings when you..
    • Move the switch from auto to off and check all of the readings.
    • Move the switch back to auto and recheck the readings.
    • Move the switch to off for a minute and then back to auto and recheck the readings.
  • What are the first seven characters of the cell and box serial numbers?
  • What is the actual salinity and how are you measuring it?
Welcome to TFP.
I will do this tomorrow.
Salinity was checked by my local pool store.
Thank you for this
Welcome to TFP.
Error Fixed, not plugged in.
Salt reading is 4000 PPM when the store has it at 3100, anything I should be concerned about?
