My AquaPure has pretty much stopped generating chlorine and I was hoping to get ideas for items to check. The system is original to the pool when I had it built, which was 3 years ago.
The "CELL ON" light rarely comes on, and it only stays lit for a few seconds when it does. I confirmed no chlorine generation by lack of bubbles in the returns (it used to generate bubbles when the SWG was working) and testing chlorine level with a dropper kit.
Here's what I've tested / tried:
* Tri sensor appears to be working. The "flow" indicator is light, and it's correctly set on Program A based on the firmware number.
* I removed the power cable to the cell and all three terminals are intact and clean. I added some dielectric grease and reinstalled but still no chlorine generation.
* The salt cell has minimal scale buildup. The plates are clean. There was just a little bit of scale at the ends.
I hate to start throwing new parts at this. If I did, I would probably start with a new control board, which is around $200.
Appreciate any thoughts or ideas on this.
