2,400/3,200 = 75% efficiency on one polarity and 2,600/3,200 = 81% in the other polarity.
At 75%, it is usually time to think about replacing the cell.
Check for scaling and clean the cell if necessary, but only if necessary.
Check the plates for corrosion.
If the plates are not corroded, you can change the cell type to T-9 and get some more life out of the cell or you can add more salt to make it work.
You should be 100% sure about the actual salinity and you never want to completely rely on any single test no matter how reliable the test seems.
I would recommend at least three different salinity tests including a calibrated meter that are all within 300 ppm of each other before I would consider the salinity to be known to a reasonable degree of certainty.
