Been three days with not a single minute of time lost. Now to see how many days, weeks, or months the fix works. I may help my pool guy fix some since he replaces these once in a while for time loss. I will buy a heat gun and some more conformal coating spray for water proofing the repair. Note: This is not an easy soldering job if you are not used to surface mount parts, don't try it. I may also buy a few 0.1uF 0805 (maybe 0603) capacitors because the bypass cap (C14) on the real time clock was a bit corroded too.
Is your pool board still fixed and not losing time ?
