Aqualogic/Goldline Relay and Breaker Replacement
May 26, 2017
6
Apex/NC
Can someone help me figure out what relay I need to order to replace the pump filter one that burned out (see pic)? Also I would like to replace the breaker attached to it. The ones I found do not have the metal bar. Is that needed? Or can I order a standard Siemens double pole 20amp breaker? If anyone knows the part numbers or where I can order them that would be fantastic. Any tips on how to replace the relay and breaker is also very much appreciated.
Look on the inside of the door for compatible circuit breakers.
You want GFCI.
Thanks for the quick reply.
Will order the relay right away.
Please excuse the dumb question but for the breaker, I found this --> https://www.amazon.com/Siemens-Q22020CT2-20-Amp-Circuit-Breaker/dp/B000VYOT9S not GFI but a closer match? I can't tell but aren't 2 of the breakers tied together to make it a quad or can they be separated? if they are separate I will order the one you suggested for sure.
Thank you again for your help.
It looks like the Aux 1 and the Aux 6 relays are not being used.
You could use one of those extra relays if you need it to work right away.
Breakers should be GFCI.
I would get 2 new GFCI breakers and remove the quad breaker.
