Hi everyone, has anyone successfully connected an Aqualink automation controller to intelligently communicate with a heat pump AND a gas heater?
Just looking for some straight answers, if there are any to be had.... I can't seem to get a straight/clean answer from documentation, Zodiac/Jandy, the PB, or the PB after service team. Been down the rabbit hole on TFP, reddit, and youtube... but I'm starting to go cross-eyed after reading the end of the internet and spending countless hours messing with the wiring/etc.
System:
fully realize this is a first world problem, but feel like its so close... (yet so far...)
Thanks!
System:
- 15k gal gunnite pool with spa
- Jandy variable speed pump, Jandy PDA-PS6 combo controller (Rev 7.2), PDA RF remote (white), iQ30 iAqualink, Raypak/Rheem gas heater, Aquacal heat pump (heat/chill)
- Cartridge filters, nature 2 fusion
- I'm under the impression that PDA-X systems are limited for advanced controls and perhaps an RS based card/system will allow better RS485 based communication (mostly based on this thread: How-to: Controlling Aqualink RS System with cheap PC hardware)
- Given up on trying all the combinations/permutations of wiring to get the Aqualink controller and Aquacal HP intelligently communicating in SMART mode for now and have purchased the Aquacal Poolsync wifi controller for the heat pump to be able to wirelessly control/set the heat pump
- Gas heater is connected with the low voltage bus bar (green bar positions 1&2)
- Pool after service folks have the HP set up with a 2-wire relay based control from the Aqualink, but only does on/off... no setpoint controls like RS485 SMART controls
Thanks!
