#!/usr/bin/env python# coding=utf-8
"""Simulates AqualinkRS square remote and spa remote with a RS485 interface."""
import string
import serial
import struct
import threading
import sys
import time
import socket
import os
from BaseHTTPServer import BaseHTTPRequestHandler, HTTPServer
import cgi
# Configuration
RS485Device = "/dev/ttyUSB0" # RS485 serial device to be used
debugData = False
debugRaw = False
# ASCII constants
NUL = '\x00'
DLE = '\x10'
STX = '\x02'
ETX = '\x03'
masterAddr = '\x00' # address of Aqualink controller
last_log = ""
ID = "40"
SPAID = "20"
INDEXHTML = """
<html>
<head>
<title>Pool Controller</title>
<script language="Javascript">
if (window.XMLHttpRequest) {
var xmlHttpReqKey = new XMLHttpRequest();
var xmlHttpReqScreen = new XMLHttpRequest();
} else {
var xmlHttpReqKey = new ActiveXObject("Microsoft.XMLHTTP");
var xmlHttpReqScreen = new ActiveXObject("Microsoft.XMLHTTP");
function screen() {
xmlhttpPost(xmlHttpReqScreen, "/screen.cgi", "", "screen");
function sendkey(key) {
xmlhttpPost(xmlHttpReqKey, "/key.cgi", "key="+key);
function xmlhttpPost(xmlReq, strURL, params, update) {
xmlReq.open('POST', strURL, true);
xmlReq.setRequestHeader("Content-type","application/x-www-form-urlencoded");
xmlReq.send(params);
if (update != "") {
xmlReq.onreadystatechange = function() {
if (xmlReq.readyState == 4) {
updatepage(xmlReq.responseText, update);
xmlReq.send();
function updatepage(str, div){
document.getElementById(div).innerHTML = str;
setTimeout(window[div](), 250);
</script>
</head>
<body onload="screen();">
<table>
<tr>
<td>
<table><tr><td height="80px" align="right"><button onclick="sendkey('pgup');">Page Up</button></td></tr><tr><td align="right" height="80px"><button onclick="sendkey('back');">Back</button></td></tr><tr><td align="right" height="80px"><button onclick="sendkey('pgdn');">Page Down</button></td></tr></table>
</td>
<td>
<font size="+2"><div id="screen"></div> </font>
</td>
<td>
<table><tr><td align="left" height="80px"><button onclick="sendkey('up');">Up</button></td></tr><tr><td align="left" height="80px"><button onclick="sendkey('down');">Down</button></td></tr></table>
</td>
</tr>
<tr><td colspan="3" align="center"><button onclick="sendkey('select');">Select</button></td></tr>
</table>
</body>
</html>
SPAHTML = """
<html>
<head>
<title>SpaLink Controller</title>
var xmlHttpReqStatus = new XMLHttpRequest();
} else {
var xmlHttpReqStatus = new ActiveXObject("Microsoft.XMLHTTP");
function screen() { /* Ping-pong between lights and lcd */
xmlhttpPost(xmlHttpReqStatus, "/spastatus.cgi", "", "cstat");
function cstat() {
xmlhttpPost(xmlHttpReqScreen, "/spascreen.cgi", "", "screen");
xmlhttpPost(xmlHttpReqKey, "/spakey.cgi", "key="+key);
if (update != "") {
xmlReq.send();
setTimeout(window[div](), 125);
</script>
</head>
<body onload="cstat(); screen();">
<table>
<tr>
<td><div id="screen"></div></td>
<td>
<table>
<tr>
<td> </td>
<td><button onclick="sendkey('1')";>Spa</button></td>
<td><button onclick="sendkey('2')";>Spa Heat</button></td>
<td><button onclick="sendkey('3')";>Jet Pump</button></td>
<td><button onclick="sendkey('4')";>Waterfall</button></td>
</tr>
<tr>
<td><button onclick="sendkey('*')";>*</button></td>
<td><button onclick="sendkey('5')";>Pool Light (+)</button></td>
<td><button onclick="sendkey('6')";>Spa Light (-)</button></td>
<td><button onclick="sendkey('7')";>Waterfall Light</button></td>
<td><button onclick="sendkey('8')";>Aux 6</button></td>
</tr>
</table>
</td>
</tr>
<tr><td>STATUS:</td><td colspan="4"><div id="cstat"></div></td></tr>
</table>
</body>
</html>
PORT = 80
class webHandler(BaseHTTPRequestHandler):
"""CGI and dummy web page handler to interface to control objects."""
screen = None
spa = None
def log_request(self, code='-', size='-'):
"""Don't log anything, we're on an embedded system"""
pass
def log_error(self, fmt, *args):
"""This was an error, dump it."""
self.log_message(fmt, *args)
#Handler for the GET requests
def do_GET(self):
"""HTTP GET handler, only the html files allowed."""
if self.path == "/":
self.path = "/index.html"
# We only serve some static stuff
if (self.path.startswith("/spa.html") or
self.path.startswith("/index.html")):
mimetype = 'text/html'
ret = ""
if self.path.startswith("/index.html"):
ret = INDEXHTML
elif self.path.startswith("/spa.html"):
ret = SPAHTML
self.send_response(200)
self.send_header('Content-Type', mimetype)
self.end_headers()
self.wfile.write(ret)
else:
self.send_error(404, 'File Not Found: %s' % self.path)
def do_POST(self):
"""HTTP POST handler. CGI "scripts" handled here."""
ctype, pdict = cgi.parse_header(self.headers.getheader('content-type'))
try:
if ctype == 'multipart/form-data':
postvars = cgi.parse_multipart(self.rfile, pdict)
elif ctype == 'application/x-www-form-urlencoded':
length = int(self.headers.getheader('content-length'))
postvars = cgi.parse_qs(self.rfile.read(length), keep_blank_values=1)
else:
postvars = {}
except:
postvars = {}
if (self.path.startswith("/key.cgi") or
self.path.startswith("/spakey.cgi") or
self.path.startswith("/spabinary.cgi") or
self.path.startswith("/screen.cgi") or
self.path.startswith("/spascreen.cgi") or
self.path.startswith("/status.cgi") or
self.path.startswith("/spastatus.cgi")):
ret = ""
if self.path.startswith("/key.cgi"):
if 'key' in postvars:
key = postvars['key'][0]
self.screen.sendKey(key)
ret = "<html><head><title>key</title></head><body>"+key+"</body></html>\n"
elif self.path.startswith("/spakey.cgi"):
self.spa.sendKey(key)
# print "SPA - key "+key
elif self.path.startswith("/spabinary.cgi"):
ret = self.spa.text() + "|" + time.strftime("%_I:%M%P %_m/%d") + "|"
if (self.spa.status['spa']=="ON"): ret += "1"
else: ret += "0"
if (self.spa.status['heat']=="ON"): ret += "1"
else: ret += "0"
if (self.spa.status['jets']=="ON"): ret += "1"
else: ret += "0"
elif self.path.startswith("/screen.cgi"):
ret = self.screen.html()
elif self.path.startswith("/spascreen.cgi"):
ret = self.spa.html()
elif self.path.startswith("/status.cgi"):
ret = self.screen.status
elif self.path.startswith("/spastatus.cgi"):
ret = self.spa.status
self.end_headers()
else:
class MyServer(HTTPServer):
"""Override some HTTPServer procedures to allow instance variables and timeouts."""
def serve_forever(self, screen, spa):
"""Store the screen and spa objects and serve until end of times."""
self.RequestHandlerClass.screen = screen
self.RequestHandlerClass.spa = spa
HTTPServer.serve_forever(self)
def get_request(self):
"""Get the request and client address from the socket."""
self.socket.settimeout(1.0)
result = None
while result is None:
try:
result = self.socket.accept()
except socket.timeout:
pass
result[0].settimeout(1.0)
return result
def startServer(screen, spa):
"""HTTP Server implementation, to be in separate thread from main code."""
try:
server = MyServer(('', PORT), webHandler)
print 'Started httpserver on port ' , PORT
# Wait forever for incoming http requests
server.serve_forever(screen, spa)
except KeyboardInterrupt:
print '^C received, shutting down the web server'
server.socket.close()
class Spa(object):
"""Emulate spa-side controller with LCD display."""
lock = None
nextAck = "00"
status = {}
def __init__(self):
self.screen = "---"
self.status = {'spa': "UNK", 'jets': "UNK", 'heat': "UNK"}
self.nextAck = "00"
self.lock = threading.Lock()
def sendAck(self, i):
"""Tell controller we got messag, including keypresses in response."""
ackstr = "00" + self.nextAck
# print "SPACK: "+ackstr
i.sendMsg((chr(0), chr(1), ackstr.decode("hex")))
self.nextAck = "00"
def setNextAck(self, nextAck):
"""Set value to send on next controller ping."""
self.nextAck = nextAck
def sendKey(self, key):
"""Send a key on the next ack"""
keyToAck = {'1': "09", '2': "06", '3': "03", '4': "08", '5': "02", '6': "07", '7': "04", '8': "01", '*': "05"}
if key in keyToAck.keys():
self.setNextAck(keyToAck[key])
def update(self, args):
"""Update the 7-segment LCD display."""
# print "SPAUPDATE"
self.lock.acquire()
try:
text = args[1:4]
if args[1:7] == " . . .":
self.screen = "... ..."
else:
self.screen = text
if ord(args[5:6]) == 1:
self.screen += " SET"
elif ord(args[9:10]) == 33:
self.screen += " AIR"
elif ord(args[7:8]) == 33:
self.screen += " H2O"
else:
print args.encode("hex")
if text == "0FF":
self.screen = "OFF H2O"
finally:
self.lock.release()
# print "SPATEXT: "+text
def setStatus(self, stat):
"""Process the status into a string for HTML return"""
try:
if ord(stat[0:1]) & 16:
self.status['spa'] = 'ON'
else:
self.status['spa'] = 'OFF'
if ord(stat[0:1]) & 1:
self.status['jets'] = 'ON'
else:
self.status['jets'] = 'OFF'
if ord(stat[0:1]) & 8:
self.status['heat'] = 'ON'
else:
self.status['heat'] = 'OFF'
except:
def html(self):
"""Return HTML formatted 7-segment display"""
self.lock.acquire()
try:
ret = "<pre>"
ret += self.screen
ret += "</pre>"
finally:
self.lock.release()
return ret
def text(self):
"""Return plain 7-character display"""
ret = self.screen
return ret
def processMessage(self, ret, i):
"""Handle controller messages to us"""
if ret['cmd'] == "03": # Text status
# print "SPA-TEXT"
self.sendAck(i)
self.update(ret['args'])
elif ret['cmd'] == "09": # Change send ??
# print "SPA-CHANGE"
self.sendAck(i)
try:
equip = ord(ret['args'][0:1])
state = ord(ret['args'][1:2])
except:
pass
elif ret['cmd'] == "02": # Status binary
# print "SPA-BSTATUS"
self.sendAck(i)
self.setStatus(ret['args'])
elif ret['cmd'] == "00": # Probe
# print "SPA-PROBE"
self.sendAck(i)
else:
# print "SPA-UNKCMD"
self.sendAck(i)
class Screen(object):
"""Emulates the square remote control unit."""
W = 16
H = 12
UNDERLINE = '\033[4m'
END = '\033[0m'
lock = None
nextAck = "00"
def __init__(self):
"""Set up the instance"""
self.dirty = 1
self.screen = self.W * [self.H * " "]
self.invert = {'line':-1, 'start':-1, 'end':-1}
self.status = "00000000"
def setStatus(self, status):
"""Stuff status into a variable, but not used presently."""
self.status = status
def cls(self):
"""Clear the screen."""
self.lock.acquire()
try:
for i in range(0, 12):
self.screen[i] = ""
self.invert['line'] = -1
self.dirty = 1
finally:
self.lock.release()
def scroll(self, start, end, direction):
"""Scroll screen up or down per controller request."""
self.lock.acquire()
try:
if direction == 255: #-1
for x in range(start, end):
self.screen[x] = self.screen[x+1]
self.screen[end] = self.W*" "
elif direction == 1: # +1
for x in range(end, start, -1):
self.screen[x] = self.screen[x-1]
self.screen[start] = self.W*" "
self.dirty = 1
finally:
self.lock.release()
def writeLine(self, line, text):
""""Controller sent new line for screen."""
self.lock.acquire()
try:
self.screen[line] = text + self.W*" "
self.screen[line] = self.screen[line][:self.W]
self.dirty = 1
finally:
self.lock.release()
def invertLine(self, line):
"""Controller asked to invert entire line."""
self.lock.acquire()
try:
self.invert['line'] = line
self.invert['start'] = 0
self.invert['end'] = self.W
self.dirty = 1
finally:
self.lock.release()
def invertChars(self, line, start, end):
"""Controller asked to invert chars on a line."""
self.lock.acquire()
try:
self.invert['start'] = start
self.invert['end'] = end
self.dirty = 1
finally:
self.lock.release()
def show(self):
"""Print the screen to stdout."""
self.lock.acquire()
try:
if self.dirty:
self.dirty = 0
os.system("clear")
for i in range(0, self.H):
if self.invert['line'] == i:
sys.stdout.write(self.UNDERLINE)
sys.stdout.write(self.screen[i])
sys.stdout.write(self.END)
sys.stdout.write("\n")
sys.stdout.write(self.W*"-" + "\n")
sys.stdout.write("STATUS: " + self.status + "\n")
finally:
self.lock.release()
def html(self):
"""Return the screen as a HTML element (<PRE> assumed)"""
self.lock.acquire()
try:
ret = "<pre>"
for x in range(0, self.H):
if x == self.invert['line']:
for y in range(0, self.W):
if y == self.invert['start']:
ret += "<span style=\"background-color: #FFFF00\"><b>"
ret += self.screen[x][y:y+1]
if y == self.invert['end']:
ret += "</b></span>"
if self.invert['end'] == self.W:
ret += "\n"
else:
ret += self.screen[x] + "\n"
ret += "</pre>"
finally:
self.lock.release()
return ret
"""Controller talked to us, send back our last keypress."""
ackstr = "8b" + self.nextAck
i.sendMsg( (chr(0), chr(1), ackstr.decode("hex")) )
self.nextAck = "00"
"""Set the value we will send on the next ack, but don't send yet."""
"""Send a key (text) on the next ack."""
keyToAck = { 'up':"06", 'down':"05", 'back':"02", 'select':"04", 'pgup':"01", 'pgdn':"03" }
"""Process message from a controller, updating internal state."""
if ret['cmd'] == "09": # Clear Screen
# What do the args mean? Ignore for now
if (ord(ret['args'][0:1])==0):
self.cls()
else: # May be a partial clear?
self.cls()
# print "cls: "+ret['args'].encode("hex")
self.sendAck(i)
elif ret['cmd'] == "0f": # Scroll Screen
start = ord(ret['args'][:1])
end = ord(ret['args'][1:2])
direction = ord(ret['args'][2:3])
self.scroll(start, end, direction)
self.sendAck(i)
elif ret['cmd'] == "04": # Write a line
line = ord(ret['args'][:1])
offset = 1
text = ""
while (ret['args'][offset:offset+1].encode("hex") != "00") and (offset < len(ret['args'])):
text += ret['args'][offset:offset+1]
offset = offset + 1
self.writeLine(line, text)
self.sendAck(i)
elif ret['cmd'] == "05": # Initial handshake?
# ??? After initial turn on get this, rela box responds custom ack
# i.sendMsg( (chr(0), chr(1), "0b00".decode("hex")) )
self.sendAck(i)
elif ret['cmd'] == "00": # PROBE
self.sendAck(i)
elif ret['cmd'] == "02": # Status?
self.setStatus(ret['args'].encode("hex"))
self.sendAck(i)
elif ret['cmd'] == "08": # Invert an entire line
self.invertLine( ord(ret['args'][:1]) )
self.sendAck(i)
elif ret['cmd'] == "10": # Invert just some chars on a line
self.invertChars( ord(ret['args'][:1]), ord(ret['args'][1:2]), ord(ret['args'][2:3]) )
self.sendAck(i)
else:
print "unk: cmd=" + ret['cmd'] + " args=" + ret['args'].encode("hex")
self.sendAck(i)
def log(*args):
"""Set the last log message"""
global last_log
message = "%-16s: " % args[0]
for arg in args[1:]:
message += arg.__str__() + " "
last_log = message + "\n"
class Interface(object):
""" Aqualink serial interface """
def __init__(self, theName):
"""Initialization.
Open the serial port and find the start of a message."""
self.name = theName
if debugData:
log(self.name, "opening RS485 port", RS485Device)
self._open()
self.msg = "\x00\x00"
self.debugRawMsg = ""
# skip bytes until synchronized with the start of a message
while (self.msg[-1] != STX) or (self.msg[-2] != DLE):
self.msg += self.port.read(1)
if debugRaw:
self.debugRaw(self.msg[-1])
self.msg = self.msg[-2:]
if debugData:
log(self.name, "synchronized")
# start up the read thread
log(self.name, "ready")
def _open(self):
"""Try and connect to the serial port, if it exists. If not, then
add a small delay to avoid CPU hogging"""
try:
if not os.path.exists(RS485Device):
time.sleep(1)
self.port = serial.Serial(RS485Device, baudrate=9600,
bytesize=serial.SEVENBITS,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
timeout=0.1)
except:
self.port = None
def readMsg(self):
""" Read the next valid message from the serial port.
Parses and returns the destination address, command, and arguments as a
tuple."""
if (self.port == None):
self._open() # Try and re-open port
if (self.port == None): # We failed, return garbage
return {'dest':"ff", 'cmd':"ff", 'args':""}
while True:
dleFound = False
# read what is probably the DLE STX
try:
self.msg += self.port.read(2)
except serial.SerialException:
self.msg += chr(0) + chr(0)
self._open()
if debugRaw:
self.debugRaw(self.msg[-2])
while len(self.msg) < 2:
self.msg += chr(0)
while (self.msg[-1] != ETX) or (not dleFound) or (len(self.msg)>128):
# read until DLE ETX
try:
self.msg += chr(0)
self._open()
if debugRaw:
if self.msg[-1] == DLE:
# \x10 read, tentatively is a DLE
dleFound = True
if (self.msg[-2] == DLE) and (self.msg[-1] == NUL) and dleFound:
# skip a NUL following a DLE
self.msg = self.msg[:-1]
# it wasn't a DLE after all
dleFound = False
# skip any NULs between messages
self.msg = self.msg.lstrip('\x00')
# parse the elements of the message
dlestx = self.msg[0:2]
dest = self.msg[2:3]
cmd = self.msg[3:4]
args = self.msg[4:-3]
ascii_args = filter(lambda x: x in string.printable, args)
checksum = self.msg[-3:-2]
dleetx = self.msg[-2:]
if debugData:
debugMsg = dlestx.encode("hex")+" "+dest.encode("hex")+" "+\
cmd.encode("hex")+" "+args.encode("hex")+" \""+ascii_args+"\" " +\
checksum.encode("hex")+" "+dleetx.encode("hex")
self.msg = ""
# stop reading if a message with a valid checksum is read
if self.checksum(dlestx+dest+cmd+args) == checksum:
if debugData:
log(self.name, "-->", debugMsg)
if args == None:
args = ""
return {'dest':dest.encode("hex"), 'cmd':cmd.encode("hex"), 'args':args}
else:
if debugData:
log(self.name, "-->", debugMsg, "*** bad checksum ***")
def sendMsg(self, (dest, cmd, args)):
""" Send a message.
The destination address, command, and arguments are specified as a tuple."""
msg = DLE + STX + dest + cmd + args
msg = msg + self.checksum(msg) + DLE + ETX
for i in range(2, len(msg) - 2):
# if a byte in the message has the value \x10 insert a NUL after it
if msg[i] == DLE:
msg = msg[0:i+1]+NUL+msg[i+1:]
if debugData:
log(self.name, "<--", msg[0:2].encode("hex"),
msg[2:3].encode("hex"), msg[3:4].encode("hex"),
msg[4:-3].encode("hex"), msg[-3:-2].encode("hex"),
msg[-2:].encode("hex"))
n = self.port.write(msg)
def checksum(self, msg):
""" Compute the checksum of a string of bytes."""
return struct.pack("!B", reduce(lambda x, y:x+y, map(ord, msg)) % 256)
def debugRaw(self, byte):
""" Debug raw serial data."""
self.debugRawMsg += byte
if ((len(self.debugRawMsg) == 48) or (byte==ETX)):
log(self.name, self.debugRawMsg.encode("hex"))
def main():
"""Start the listener for a screen and spa, run webserver."""
print "Creating screen emulator..."
screen = Screen()
print "Creating spa emulator..."
spa = Spa()
print "Creating RS485 port..."
i = Interface("RS485")
print "Creating web server..."
server = threading.Thread(target=startServer, args=(screen, spa))
server.start()
print "Main loop begins..."
while True:
ret = i.readMsg()
# print "ATTN: "+ret['dest'];
if ret['dest'] == ID:
screen.processMessage(ret, i)
elif ret['dest'] == SPAID:
spa.processMessage(ret, i)
if __name__ == "__main__":
main()
