Moved from here.
@HermanTX I am having the same issue. I am able to set date and time and run all the equipment from the RS4 controller but when I go to program, is says to select equipment to program and then just says “not programmable”.Follow the manual. Set the date and time so all your other efforts make sense. After that, you need to go to program and it will ask what piece of equipment to program.
Are you able to turn your pump on and off from the wall panel? It would be that top left button which has the LED light on it.
