- Mar 1, 2013
- 107
- Jandy Aquapure 1400
I noticed my AquaLink Air Sensor is way off with its temp readings. This is problematic since my freeze protection is triggered by this sensor. It’s reading a lot higher than actual air temp. It’s not in the sun and mostly I’m concerned at night when it’s getting into the 30s. 1) do these go bad and 2) I don’t think you can calibrate the air sensor so is there anything else to try other than try to replace?
I know they’re easy to replace but I want to checking I was missing something obvious. Do the boards go bad?
Thank you.
Thank you.
