Aquacal Heat Pump Wont Turn Off
Jul 7, 2017
14
Suffolk County/ NY
Aquacal SQ145. 3 years old.
Heater won't turn off. I have to turn the breaker off.
The heater is kicking on and off when I adjust the temperature and producing heat.
I change the mode to off and it still runs.
I turn off my pump and it stays running.
Any ideas?
Thanks
Bill
Jandy, Hayward and Pentair all make pool automation systems that control the various pieces of equipment. It's a box that mounts on the wall and all of the equipment connects to the box for power and control.
Has the heat pump always worked correctly from installation?
Maybe a bad relay going to the fan or some reason that that the circuit thinks the fan needs to run or a bad circuit board.
You're not getting any errors indicated at all?
When ice starts to form on the coil, the compressor will stop operating while the fan continues to operate.
The coil will begin to warm to the surrounding air temperature. When the coil's temperature rises above 38° F, the compressor is restarted and heating resumes.
If the coil's temperature remains below 38° F, the compressor will remain off.
Does the display say "Defrosting"?
