Aquabot 4x4 blinking - Not power on
su100
1
Spain
I had an Aquabot 4x4, when i press the button on power supply, it start to blinking fast and then return to "standby" mode. Unit not start. If I unplug the unit from power supply and then i press button, led on power supply keeps on as it is working. Any idea? I'm thinking if there are any problem on 4 pins connector, I check current tension between pin 1 and pin 4 are 27 v. Some help will be apreciate. Thanks!
Welcome to TFP.
It does not seem anyone knows about your cleaner.
