Aqua Plus control stated shutting the pump off shortly after the chlorinator starts. If the chlorinator is disabled, it still turns off at about 1 minute.
Details:
1) Flow Switch shows FLOW just before shut off (continues to show flow if pump running from pump controls & not comm)
2) Chlorinator continues showing voltage and salt
3) Switching polarity has no affect on the issue
4) Disconnecting comm to the pump and running it from the pump control panel allows pump to run without issue (chlorination also will work normally during this mode)
5) No messages on control panel, except when comm is off of pump to run pump manually a comm message will appear
6) New filters installed, baskets free, pressures normal
Details:
