STARLOG: April in the "D"
(D=dome, not Detroit
Well, its April, normally season opener for me...This morning the dome air hit 80 (outdoor temps 50s) and I'm not needing more than 5 hours of energy or 10 CCF to maintain 95 all day/night.
Given our low night temps in April and much of May, I'm targeting approx May 15 for takedown, which promises to be shenanigans-filled-foolery.
In my routine maintenance, I've discovered a few fun facts I'll share for posterity:
1. Hornets can indeed breach the dome. Sigh.
2. So can ants.
3. With such high internal daytime air temps, regular mopping of the apron where condensation collects with a diluted chlorine solution is necessary at least weekly to stave off algae growth outside of the pool...I now keep a spray bottle and soft mop inside to do so.
4. All marine grade stainless steel is not created equal. My swivel hooks have remained pristine in the water (use them to connect the nylon line through my PVC cover hoder.) My large hook on deck attached to diving board to secure cover in half open position, not so much, despite its claims of "marine grade."
4. All brass fitting are not created equal, and some have large amounts of ignoble zinc in the mix. This I learned when my bricolered air warmer fitting corroded straight through and began leaking on the outside of the air warmer exchanger. I was able to repair and replace with sprinkle swivel parts made of PVC, which I now realize I should have done in the first place. Next year will retrofit my return valve diverter connection and cut down the commercial hose end to take a PVC pressure fitting.
5. The sole disadvantage of my in-pool diverter valve is that when the sun is quickly warming up the dome air, you have to go inside to shut it down if you don't want to add heat to already warm air. This isn't an issue yet most days, but as temps approach 70s outside during the day, will become more of a PITA. Otherwise, the system worked very well, with excellent gains.
6. The plan for storage is forming. We purchased a little resin Kettering 3'x4' shed to assemble under the astro crib deck, well shaded and out of the weather. Once the dome is down, dried, talced, accordion folded and put into its custom bag, its going into the shed, which we hope to fully seal from rodents. We'll keep you posted on success or failure of that plan.
Open Air Operation:
With the goal of sustainable, yearround energy costs, we're going to be "inventing/experimenting" with a fixed Rocky Reel cover, mounted on a swing swivel marine plate used for boating stools. The "cover/open" position will run perpendicular to our grecian's length, positioned about 3' from the end. Instead of anchor holes on the swing side, we're planning to drill and line with 1/2" copper tubing treated with corrosion resistant film (marine style). We've bought 4" 3/8 coated pins to lubricate and drop to hold in position when cranking and are devising a handle strap to then walk the swinging rolled up reel and còver into "storage/open pool" position, where it will be secured by dropping pins into the sleeves we'll install there. It will be a few weeks until I discover all the things wrong, or right, with this idea as this weekend is devoted to pool house painting and shed assembly
But I'm lovin the year round swim time, despite minor engineering trials and triumphs
