Hello All,
I was wondering if anyone had a suggestion of introducing air bubbles into the main drain? I think the girls would get a kick out of such a feature. Not your typical bubbler which creates a fountain affect on the surface. I just want a lot of bubbles to come out of the main drain and rise to the surface.
I have a typical circulation setup whereas a three way valve is used to control the inlet water between the skimmer and main drain. I however could easily redo the plumbing and add another valve to make the main drain both and inlet and outlet. However, what would I use to blow air through the plumbing to create these bubbles?
Ralph
Ralph
