tf,
I saw this the other day and decided to give it a try.. I bought the Pentair version, which of course cost more..
It appears to be the same except comes with 8 oz. of reagent.
Pros...
I love the sliding dot!!! I find that, for me, I get very repeatable results, where not so much with the fixed dot.
It has now become my primary test for CYA.
Cons..
It takes a lot more reagent per test, about 1 oz. The linked unit comes with 4 oz or only 4 tests.
The inside of tube turned hazy after two tests.. but then so did my TF-100 tube. Because of the fixed sliding dot mechanism it will be much harder to clean, which I have not yet done. Have no idea if that will be a problem later on or not..
The sliding dot mechanism is very sloppy.. So once the dot disappears it is hard to hold the slide and then look at the scale. I did find, after a few tries, that if I use one finger on the slide to take out the slop, that I can hold the slide in place and then read the scale.
Just like all CYA tests the scale gets closer together the higher you go. The scale does stop at 60 and then jump to 100, but in my case anyway, knowing I am above 60 and below 100 is all I need. Although not as accurate, you can still make a logarithmic "guess" at where you are and be pretty close.
The kit is bigger than the TF-100 and takes up more room in my carrying case.
Thanks for posting,
