Hi there everyone!
I'm on my 6th day of the SLAM process -(Technically my 15th day , but my first 7 days were wasted because I thought my shock level was supposed to be 16 ug) - but I seem to be getting nowhere.
16.5K pebble pool
Bleach for regular chlorination and shocking
Cartridge filter (Cleaned last sunday)
CYA =50
pH = 7.4 (before shock)
Alk = 90 (before shock)
Hardness = 450
Had a little algae growing that most would not even notice, so it wasn't a swamp or anything to begin with.
Filter running continuously (evenings down to slow speed)
Shocking at 20ppm and testing w NEW dpd powder and new R-0871
Water is clear and pool looks great, actually!
Brushing all areas at least 2 times a day
removed light fixture and cleaned socket as well.
Overnight test results losing 2-2.5ppm at night with 1ppm CC.
Adding 10% bleach throughout the day to maintain shock level.
Today, after this morning's test and adding to bump up to 20, I tested again at 11:00am, had lost about 2ppm (down to 18).
Added bleach once again to get back up to 20.
Waited about two hours, and decided to check again, and level was down to 16ppm. Did the test again to make sure I wasn't losin' it, and still shows 16ppm.
So.,,. within 2 hours, I have lost 4ppm ! This is on day Six of shocking and attempting to maintain 20ppm.
To confirm testing steps:
Add water from 18-20" down in pool water to 10mm in (clean) vial
Add two leveled-off spoons of DPD powder and swirl to mix.
Add R-0871 drops one by one carefully while swirling until pink turns clear. Then divide drops by 2.
Any ideas or suggestions would be great. I have literally added about 20+ gallons of HDX(home depot) chlorine bleach to this pool over the past week or two.) and I'm about to give up and fill this money pit with dirt.. LOL
Thanks in advance!
John
16.5K pebble pool
CYA =50
Hardness = 450
Thanks in advance!
John
