I have some boric acid on order from The Chemistry Store. When it gets here I will do a density measurement.
This forum is my most definitive source! Aside from what I pointed to previously, there's nitro's article How do I use Chlorine in my spa. It recommends CH=100-150, TA=50-80, CYA=20-30 or so (but up to 50 is really ok). There is also some talk about how FC ought to be nudged up a bit as well, compared to the usual FC/CYA chart, as FC doesn't last as long in the higher temps and especially with higher bather loads.JasonLion said:If you know of a definitive source for recommended levels for a spa I would be happy to put them in.
JasonLion said:My Pool Calculator is now available for the iPhone.
JasonLion said:heatmisr, WM? I assume you mean Windows Mobile. I will add that to the wish list.
I received my Boric Acid from The Chemistry Store and I measured it's density and got 0.99 g/ml. This is after tapping the measuring cup to settle the product which is what I usually do. So perhaps what they sent me is ground a little finer. 2 cups (473 ml) measured as 16.5 ounces weight (468 grams).JasonLion said:I got my boric acid from The Chemistry Store. It is 20 Mule Team brand"technical grade" (whatever that means).
1 cup weighs 7.2 +-0.1 oz. The +-0.1 oz seemed to be some mixture of different amounts of tapping and not getting the measuring cup the exact same amount full each time. Without tapping I got 7.1 +-0.1, so not much variation really. Doing some conversions I get 0.86 g/ml.
I updated my Pool Calculator beta with my density measurement.
