- Oct 1, 2021
- 1,434
- Plaster
- Pentair Intellichlor IC-60
Good news. Passed OCLT. FC=9.5 CC=0 both during evening and morning test. Tested twice each time.Could also be easily proved by Overnight Chlorine Loss Test
I see what you mean. I have the pump running alone for one hour before the SWG turns on and one hour after the SWG turns off to 1) help with the scaling issue 2) as another check that my SWG runs while my pump is on in case there’s ever a clock issue.You may find that the cell will develop scale much faster when running at 100% even when accounting for run time.
Seems best path forward is to continue monitoring the FC and adjust the SWG run time and % as needed. Spring is a tricky time here because we get extra sunny days mixed with some overcast days. And this shoulder season also leads to the start of some heated pool use.
