- Apr 11, 2021
- 74
- Plaster
- CircuPool Core-35
Hi - I am installing a CORE-35 SWCG this weekend. My current plumbing only really has one straight run on the return side where it makes sense to install this. I've outlined it in red in the attached picture. Just in case anyone is curious, the valve on top allows me to switch the return from the jets to the waterfall, but I only use that occasionally so I don't feel the need to rework everything to get the SWCG before this junction as it would require pretty extensive rework of the plumbing.
Has anyone else installed a CORE-35 vertically? Some googling suggests that it shouldn't be a problem, but I just would love to know if anyone else has done it and if there are any downsides I'm not thinking about here.
The other option would be to hack off the elbow there and install a straight run of about 18" for the SWCG then snake it back down to the bottom. This would get me a normal horizontal installation but I'm not sure it's worth it. Your thoughts & recommendations are welcome. Thank you in advance!
