- Jun 23, 2014
- 66
- Plaster
- Hayward Aqua Rite (T-15)
I used rv antifreeze from walmart. I believe it was the super tech stuff. I have two return lines, two skimmer lines, and a main drain. It took about 4.5 gallons to fill them all. Even if I opened to waste, I would still have over 2 gallons of antifreeze in the pool. I just started everything up, and let it all go in the pool. I didn't notice any excessive chlorine use or any cc's. I don't know if I'm the exception or the norm, but I don't plan to try to suck antifreeze out of my lines.
How long does it take for the smell to go away from the antifreeze? After two weeks, I can still smell it fairly strongly from over 40' away from the pool.
Hi guys.
I just want to check something. Both Toofast and Mr. Gunite said they bought "Super Tech" antifreeze from Walmart. Just to confirm, did you use THIS (pink) antifreeze (for RVS) and NOT automotive (blue) right?
(If you used automotive instead, my "googlresearching" would suggest a toxic byproduct that would need to be drained.)
ALSO, Chemgeek, there is another thread where the user reported a high chlorine consumption and high ccs...whereby he has started to wonder if antifreeze got in the pool (small size in terms of gallons, ergo perhaps a higher concentration if this is the culprit.)
Just for your research/observation and to assist Fungi (user name, not the substancehere is that link: http://www.troublefreepool.com/thre...after-4-days-of-filtering?p=808566#post808566
That's exactly what I used Swampwoman. Walmart had pallets of it stacked in the aisles all around the store at pool closing time here.
