About to sign a contract for a new pool on our new construction (not yet built home). We are some what limited on space as we have a detached garage on the rear of the lot. We are completely new to pool ownership and very confused. I feel like we are getting a lot as a package, but maybe not. What questions should we be asking before signing, what things should be changed, options we should consider, and what's missing (I don't see a skimmer setup anywhere?). Price ~$75k
We are also trying to consider how to maximize green space in our backyard given the limited space we have for pool placement - shift spa/shelf location, envelope of pool, change pool steps, etc. I welcome input here too .
- Pool 12 x 25
- Spa 6 x 6, spillover with 6 jets (spa can be increased up to 50 sq ft at no additional cost)
- Sun shelf 5.5 x 10 on each side
- Up to 6 well points
- Depth 3.5' to 5'
- 1 LED Bubbler and 1 Umbrella Holder
- Premium Equipment Package
- Pool Pump: Intelliflow 2.5 - 3hp variable speed, energy efficient
- Heat Pump: Ultratemp 110 Heat pump, sized accordingly (and 3x3 slab)
- Filter Cartdige: Clean and clear 150sf
- Salt Chlorinator: Pentair IC 40
- LED Color Lights; Microbrite Nichless (one in hot tub, two in pool)
- Automation: Pentair easy touch 8 Automation (with phone control)
- Valves
- Independent breaker for heat pump
- Homerun electric run to equipment
- Other
- Premium waterline tile, Level 1 PebbleTec/Sheen
- 2" Deco drain
- 700 square feet of decking
- Wall and main drain fittings
