I've got a ~10 yr old pool that I've owned for 2 yrs in Houston. The old color changing color wheel lights developed a leak in the gasket and the internals rusted a bit. I wanted to upgrade these old lights to color changing LEDs.
I started trying to pull out the shortest cable run (about 20' by surface distance and the actual cable run can't be longer than 30'). The cable won't budge. I tried pulling on both ends and am not getting anywhere. I dumped water down the conduit, let it sit, and tried tugging again. Nothing. I ran a fish tape down from the equipment junction box and got about 22' before I hit something. When I try to fish in from the niche I only get about 6" before I hit something. I'm afraid there is a 90 degree corner coming out of the pool concrete. Is that possible? When I look at the back of the niche I don't see any epoxy, star nuts, or putty.
Any suggestions? Next I'm going to try dumping wire-lube down the conduit and wrapping the cable and grounding wire (edit: I was confusing the bonding and grounding systems) around a handle pulling from the niche.
