I have been a lurker for the past few months and I think it might be time to pull the trigger. I got a few bids about 6 months but decided to hold off at the time. With the heat we've had in the past few weeks I started toying with the idea again. We are on diamond shaped lot with most of the space towards the side of the yard but I don't like the idea of having the pool on the side so here we are trying to fit it directly behind the existing back patio. About a year ago the city started to implement a 10ft build line as opposed to the standard 7ft utility easement so there goes 3ft of extra spaces. The left edge of the patio is about 25ft from the fence with the distance increasing the further right you go. Below are images of the design and the proposal made by the PB we decided to go with.
Anything I should add/remove?
Does everything look good in terms of equipment and specs?
Thanks in advance.
Pool size : 13x31
Pool Depth: up to 6ft
Pool area :359 sq ft
Pool Volume: 9700 gallons
Mechanical Equipment
Filter: 48 sq ft - Pentair FNS Plus D.E. Filter
Pump: 1.5 HP - Pentair Whisperflo Pump
Valves: Never Lube Valve 2”-2.5”
Skimmers: 2 CMP; 2-in Lines Separate Line & Valves Tan Skimmer Lids to Match Deck
Pool Light: 1 x Pentair IntelliBrite Pool Color LED w/ GFCI
Cleaner: Pentair Racer LS
Santizer: Pentair iChlor Salt System
Ozone: Ozone Joe Water Purification System
Inlets: 5 pool return inlets
Main Drains: 2 Main Drains - Separate Lines & Valves
Structural Pool Specs
Beam: 4 Bar Box Beam w/ #4 Rebar Continuous
Walls/Floor: #3 8”x8” on Center Both Ways w/ #3 Alternates
Gunite: 6 to 1 Cement to Sand Ratio
Gunite Beam: 12” Minimum, 8” Cove
Gunite (Walls/Floor):6” Minimum
Steps/Benches: Per Plan
Plumbing Specifications
2” Suction, Separte Lines, Separate Valves
PVC Schedule 40 On All Pool Piping
PVC Schedule 80 On All Pump Connections
2” Returns To 1st “T”
Electrical & Gas
All Electric Hook Up Included 25 Linear Feet Gas Hook Up Included
Tile, Coping & Interior Finish
Tile: 6-inch Water Line Tile ($6.00 per sq. ft. allowance)
Tile: 2” Tile Trim on Steps and Benches - Choice
Coping: Classic Travertine
Interior Finish: Quartzscape (Tier 1)
Deck Specs
Type of Deck: Spray Deck
Area of Deck: 535 ft²
Additional Deck: $11.00 per additional sq ft
Steel Schedule: 15-in O.C. Both Ways
Pool Maintenance Equipment
Pole: 8’ to 16’ Telescoping Pole
Wall Brush: Heavy Duty Gunite Brush
Leaf Net: Deluxe Skimmer Net
Test Kit: Deluxe 5-Part DPD Test Kit
Miscellaneous
Underground 3/4” Fill Line to Hose Bib with Vacuum Breaker
Concrete Equipment Pad Poured In Place
Start-Up Chemicals & Water Stabilization
6lb FiberClear Filtration Media
6lb. Poolife Stabilizer
12lb. Poolife Turbo Shock
4 gallons of Muratic Acid
4lb. 3” Multipurpose Chlorine Tablets
1qt. Poolife Intensive Stain Prevention
Thanks in advance.
Pool size : 13x31
Electrical & Gas
Deck Specs
Miscellaneous
