I joined summer before last and you guys taught me so much about pool chemistry and once I fixed my problem it was smooth sailing. I didn’t bother with the pool last year at all and my pump did set up and probably got some nasties inside of it but I have backwashed it a few times this year until the water runs clear.
Yet the pool I put up this year is still cloudy. Over the last week or two I was adding chlorine when it appeared cloudy because it tested zero and it would improve although the chlorine would be gone again by the next day. When my chlorine tested zero again last night, I added chlorine as normal and now the water is even more cloudy. I know I need a little CYA but otherwise I’m not terribly out of balance.
I thought about the slam method but the free chlorine is one which is technically within range so I figured that’s not what I need
Any ideas?
Any ideas?
