Hi all - while digging around getting things ready to plumb together for our pool season I've realized that our pump is not bonded properly (inherited pool / equipment). I did a lot of poking around to learn what I need to do & came up with a tentative plan, but wanted to solicit some advice / input from those that have experience. Apologies for not using the proper terminology.
Our pool has coated metal supports & shell. I tested for continuity and the upright supports, top rail and top lip overhangs are "connected", but the shell is isolated from these components, but connected to the bottom metal skirt. I did find the seam (luckily right next to where the pump goes!) and there is continuity between the seam bolts & the shell (& bottom skirt).
Here's what I was planning (all attachments using lugs or proper bonding "t" connectors):
#8 bare copper wire from pump to seam bolt (bond to shell & bottom "skirt")
#8 bare copper wire from support bolt to pump-seam wire (bond to supports, top rail, etc)
Some sort of skimmer bonding device, with the copper wire attached to the pump-seam wire (bond to water)
To those familiar, does this seem like it would bring us within compliance (and, more importantly, ratchet up our safety factor)? I'm hoping I can avoid the need for a bonding "grid" around the pool, as given the deck and hill, that would be a TON of work.
I also have a metal outlet on-off box (rated for wet environments) close to the pool that runs the pump - should I include that in the bond as well? If so, any thoughts on how (attach bare copper from pump to switch ground, or outside screw, etc)? I do need to replace this with a twist lock outlet at some point, but that's for another day.
Thanks for any advice. Can't wait to get that cover off and start getting the pool ready!
