Hello All,
I have a 7yr old Pentair Master Temp 400 that is turning on and off right when it heats up to 90 deg. with a "service heater" light coming on at shutdown.
Here's the twist in the equation while in the Spa Heating mode as the temperature is increasing before hitting the 90deg. mark, when I turn on the jets the heater shuts off?
Turn the jets off and the heater will the n start back up.
I have replaced All the sensors and the thermal regulator except for the pressure switch, Heat Exhaust temp was 309, filter pressure is 19.
Yesterday while in the heating mode I unplugged the PS lead and the heater shut off I also jumped the PS leads while heating up and the unit shut off at the faithful 90deg. mark.
For some reason I think it might be the PS because when the jets come on that increases the water pressure going through the heater right ? and the heater shuts off !! Is there a correlation here IDK
There are no visible corrosion issues or leaks, the unit looks great.
What else could it be and I missing something ?
Is my heater core shot ?
Thanks in advance.
Bill
Thanks in advance.
Bill
