Need help diagnosing.
Long story…
My mastertemp 400 sprung a leak in the exchanger about 2 years ago. I patched it with JBweld and it held until a week ago when my heater stopped working as the patch failed.
I bought a new heat exchanger, and when I went to replace it, noticed the combustion chamber was rusted out as well as the lid…. I ordered a new one and was informed they are 7 months backordered!!! Since i bought the 800 buck exchanger, i am in too deep and should have bought a new heater…. Anyway…. i repaired the combustion chamber and lid with steel sheet and high temp mortar to get through the season but now my heater short cycles. I bought all new sensors and it still short cycles. i believe i may have either a grounding issue, or flame sensor voltage
The heater does light, first time for 30 seconds, then 5 seconds several times before locking out…. I checked the flame sensor voltage and its barely below 1…. With my metal hack, im wondering how to test grounds or voltage? Im at the point of about to try buying a new fenwal.
Is there a way to bypass the fenwal to make sure its bad? How do you check ground? I pull the wire from the valve and it shuts off… flame sense voltage is around 1…
What do i try next?
Long story…
What do i try next?
