After the first one kept resetting itself, I switched to this outdoor timer for about $17. So far it survived a 2" thunderstorm and worked fine for 3 days.
Cool, I'll have to look into that model to see if its available for 220v load ....cwuffman said:After the first one kept resetting itself, I switched to this outdoor timer for about $17. So far it survived a 2" thunderstorm and worked fine for 3 days.
cwuffman said:I doubt it, but it never hurts to look. You must have purchased a 220 VAC Stenner pump, huh?
shuye said:Great information - Thanks. I think I am going to set up something similar. How strong is the chlorine smell around the tank? Is is sealed really well?
Cajun said:I'm looking into these pumps and my question is why did you get the 10 gallon per day vs the 3 gallons per day? I know you just set the run time based on your need but if you would never need more than 3 gallons a day anyway wouldn't it be better to run this pump longer at a slower rate to even out the adding of chlorine. Maybe there is another reason the 10 gallon per day was selected so I'm curious.
Thanks
shuye said:Thanks. One more question, with the pump hooked into the Chlorinator, do you have the Chlorinator valve turned on also?
roadking00 said:shuye said:Thanks. One more question, with the pump hooked into the Chlorinator, do you have the Chlorinator valve turned on also?
Not sure what you mean ?
Cajun said:Carl,
Thanks for the clarification on the pump. I get what your saying the 3, 10, and 22 GPD pumps all have the same motor and it runs at a constant speed and the gearing or transmission or tubs size that attaches to the pump is what controls the output volume. I would get the 10 GPD as well. I really like these setups and I have extra space on my controller so I could easily add this to the program cycle. The pictures you added were very helpful for me to understand how this is hooked up and where the injection is going, so thanks.
I have a few questions.
1. Is this pump loud? No. It is actually acceptably quiet. I think I read in other posts that the variable speed versions may be louder.
2. It looks like you feed this into your inline chlorinator but I have heard if tabs and bleach ever mix its bad news. Are you completely tab free and you did this purely for convenience or do you still use tabs on occasion (I know I use them when I need to raise my CYA) ETA>>> I see you answered this question earlier while I was typing this post>>>It seemed to me that after the system was tablet free and adequately flushed out, there shouldn't be any problem. (Experts please correct me if I am wrong.) I still plan to use up my tablets if I need to increase stabilizer (Stenner pump off, of course!
3. I have always heard its a bad idea to store bleach outside in the heat but that's exactly what these setups do. Any reduced chlorine effects noticed from doing so? I've not noticed reduced effects. But I only recently installed this system. I haven't seen any problems mentioned in other posts involving injection or Liquidator.
4. The liquidators are designed to keep the salt from bleach at the bottom of the tank. (is there a way to do that with this system? I'm not even sure what causes the salt to be removed in the bleach while inside the liquidator, Is it because the liquidator mixes water with the bleach? Could adding water to this container do the same thing?) I guess I'm looking for the best of both worlds. Again too little history to respond. Having studied both systems, I just couldn't ever get a warm fuzzy feeling from the description of the Liquidator method: strong bleach on the bottom, diluted on the top, continuous water flow through the system yielding consistent chlorine????? Comments on this forum seem to be very positive, though. For me the injection system is just a lot simpler and easier to control.
Thanks
shuye said:Carl and RoadKing -
Thanks for the info - the pump (or Liquidator) looks like the way to go if you are going to be using bleach. The main advantage of pucks is that they are easy to use and you don't have to add them every day (CYA is the big drawback of course). I am looking for a good solution to adding bleach on a regular basis and not having to manually do it every night, especially if we go out of town for a few days or I go on a business trip.
Steve
